[GRASS-dev] r.stream.extract - grass7-addon
Helmut Kudrnovsky hellik at web.de
Sat Nov 24 04:33:28 PST 2012
>I could not reproduce this, but I guess that the parser changed
>somehow. The d8cut option of r.stream.extract is adjusted in r53993,
>please test.
tested with the nightly build of osgeo4w-wingrass7 and -addons:
r.stream.extract --verbose elevation=srtemgeahydrodem at rstream
accumulation=srtemgeahydrodemaccum at rstream threshold=500 stream_rast=rui
stream_vect=vui direction=rfld
18.21% of data are kept in memory
Will need up to 1.91 GB (1954 MB) of disk space
Creating temporary files...
Loading input maps...
Initializing A* Search...
A* Search...
Extracting streams...
Thinning stream segments...
5925 of 45839 stream segments were thinned
Writing raster maps
Writing vector map <vui>...
Writing vector attribute table
(Sat Nov 24 13:32:18 2012) Command finished (8 min 15 sec)
thanks for the fix, it works now.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-stream-extract-grass7-addon-tp5018389p5018528.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
