[GRASS-dev] error in g.extension and help file not installed
Paulo van Breugel p.vanbreugel at gmail.com
Mon Nov 26 00:54:15 PST 2012
Hi, this is on Ubuntu 12.10
On 11/25/2012 01:35 AM, Markus Neteler wrote:
> On Fedora it works, which Linux do you use? Please post that to the
> list, thanks.
> Markus
> from: Paulo van Breugel <p.vanbreugel at gmail.com>
> to:   GRASS developers email list <grass-dev at lists.osgeo.org>
> subject:  Re: error in g.extension and help file not installed
> In addition: I noticed that after opening the module the help file
> shows (the 'manual' tab in the modules window), but without the upper
> part with synopsis, flags and parameter. This has perhaps to do with
> the error message mentioned below:
>> When trying to install an add-on with g.extension, it actually get's
>> installed, but the error message tells me the install failed. The
>> example below is with r.mess, but the same happens with other add-ons.
>> Fetching <r.mess> from GRASS-Addons SVN (be patient)...
>> Compiling...
>> /usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Scri
>> pt.make:47: warning: overriding commands for target
>> `install'
>> /usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Rule
>> s.make:90: warning: ignoring old commands for target
>> `install'
>> `install'
>> `install'
>> `install'
>> `install'
>> ERROR: G_getenv(): Variable LOCATION_NAME not set
>> /bin/sh: 1: cannot create /usr/local/grass6.4.current/grass-
>> 6.4.3svn/locale/scriptstrings/r.mess_to_translate.c:
>> Directory nonexistent
>> `install'
>> `install'
>> `install'
>> `install'
>> Installing...
>> `install'
>> `install'
>> /usr/bin/install: cannot stat
>> `/home/paulo/Data/GRASSdb/test/PERMANENT/.tmp/paulo-
>> HP-Z600-Workstation/9886.0/r.mess/man/man1/r.mess.1': No
>> such file or directory
>> make: *** [install] Error 1
>> Installation failed, sorry. Please check above error messages.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121126/23b9a160/attachment.html>
