[GRASS-dev] [GRASS GIS] #1744: v.out.ascii: export all columns
GRASS GIS trac at osgeo.org
Mon Oct 1 02:33:27 PDT 2012
 Reporter:  lucadelu              |       Owner:  martinl
     Type:  enhancement           |      Status:  assigned
 Priority:  normal                |   Milestone:  7.0.0
Component:  Vector                |     Version:  svn-trunk
 Keywords:  v.out.ascii, columns  |    Platform:  All
      Cpu:  Unspecified           |
Comment(by hamish):
 This is very useful, thank you both for the suggestion and the patch.
 did v.out.ascii columns= ever get fast? It used to be unusably slow when
 there was > ~10000 db rows since it was opening and closing the db for
 every entry. I have a vague recollection that MarkusM commented at some
 point that this was needed to ensure data integrity? (I may be confusing
 that with a similar situation elsewhere in the db code)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1744#comment:5>
