[GRASS-dev] compiling error wingrass7 in temporal gis
Helmut Kudrnovsky hellik at web.de
Wed Oct 3 11:36:32 PDT 2012
hi,
osgeo4w-build-environment, win7-64-bit
svn r53310
GRASS GIS compilation log
Started compilation: Wed Oct  3 18:13:55 GMT 2012
Errors in:
/osgeo4w/usr/src/grass_trunk/temporal/t.create
myricaria at MYRICARIA-HP /osgeo4w/usr/src/grass_trunk/temporal/t.create
$ make
if [ "/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/scripts/t.create.py"
!="" ] ; then
GISRC=/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocati
on/.grassrc70 GISBASE=C:/OSGeo4W/usr/src/grass_trunk/dist.i686-pc-mingw32
PATH=
"/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/osgeo4w/usr/src/grass_t
runk/dist.i686-pc-mingw32/bin:$PATH"
PYTHONPATH="C:/OSGeo4W/usr/src/grass_trunk
/dist.i686-pc-mingw32/etc/python;C:/OSGeo4W/usr/src/grass_trunk/dist.i686-pc-mi
ngw32/etc/python;$PYTHONPATH"
PATH="/osgeo4w/usr/src/grass_trunk/dist.i686-pc-m
ingw32/bin:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/osgeo4w/usr/s
rc/grass_trunk/dist.i686-pc-mingw32/lib:.:/usr/local/bin:/bin:/mingw/bin:/osgeo
4w/bin:/osgeo4w/bin:/c/Program Files/Common Files/Microsoft Shared/Windows
Live
:/c/windows/system32:/c/windows:/c/windows/System32/Wbem:/c/windows/System32/Wi
ndowsPowerShell/v1.0/:/c/Program Files (x86)/Common Files/Roxio
Shared/DLLShare                                          d/:/c/Program
Files/WIDCOMM/Bluetooth Software/:/c/Program Files/WIDCOMM/Blueto
oth Software/syswow64:/c/Program Files (x86)/ATI
Technologies/ATI.ACE/Core-Stat
ic:/c/Program Files (x86)/Common Files/Roxio
Shared/OEM/DLLShared/:/c/Program F
iles (x86)/Common Files/Roxio Shared/OEM/DLLShared/:/c/Program Files
(x86)/Comm                                          on Files/Roxio
Shared/OEM/12.0/DLLShared/:/c/Program Files (x86)/Roxio/OEM/Audi
oCore/:/c/Program Files/TortoiseSVN/bin:/c/Program Files
(x86)/Hewlett-Packard/                                          HP
ProtectTools Security Manager/Bin/:/c/Program Files (x86)/Microsoft SQL Serv
er/100/Tools/Binn/:/c/Program Files/Microsoft SQL
Server/100/Tools/Binn/:/c/Pro                                          gram
Files/Microsoft SQL Server/100/DTS/Binn/:/c/Program Files (x86)/MicrosoftSQL
Server/100/Tools/Binn/VSShell/Common7/IDE/:/c/Program Files
(x86)/MicrosoftSQL Server/100/DTS/Binn/:/c/Program Files (x86)/Microsoft
Visual Studio 9.0/Co
mmon7/IDE/PrivateAssemblies/:/c/Program Files
(x86)/Intel/Services/IPT/:/bin:/o
sgeo4w/apps/Python27/Scripts:/bin" LC_ALL=C
686-pc-mingw32/scripts/t.create.py --html-description < /dev/null | grep -v
'</                                          body>\|</html>' >
t.create.tmp.html ; fi
  File
"C:/OSGeo4W/usr/src/grass_trunk/dist.i686-pc-mingw32/scripts/t.create.py",
line 59, in <module>
    import grass.temporal as tgis
  File
"C:\OSGeo4W\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\temporal\__init__.py",
line 9, in <module>
    from space_time_datasets import *
  File
"C:\OSGeo4W\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\temporal\space_time_datasets.py",
line 27, in <module>
    import grass.lib.vector as libvector
  File
"C:\OSGeo4W\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\lib\vector.py",
line 23, in <module>
    _libs["grass_vector.7.0.svn"] = load_library("grass_vector.7.0.svn")
  File
"C:\OSGeo4W\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\lib\ctypes_loader.py",
line 55, in load_library
    return self.load(path)
  File
line 221, in load
    return _WindowsLibrary(path)
  File
line 207, in __init__
    self.cdll = ctypes.cdll.LoadLibrary(path)
  File "C:\OSGeo4W\apps\Python27\lib\ctypes\__init__.py", line 431, in
LoadLibrary
    return self._dlltype(name)
  File "C:\OSGeo4W\apps\Python27\lib\ctypes\__init__.py", line 353, in
__init__
    self._handle = _dlopen(self._name, mode)
WindowsError: [Error 127] Die angegebene Prozedur wurde nicht gefunden
make: *** [t.create.tmp.html] Error 1
rm t.create.tmp.html
and also a windows error-message pops up:
"sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll"
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/compiling-error-wingrass7-in-temporal-gis-tp5006208.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
