[GRASS-dev] [GRASS GIS] #1759: Selecting maps in dropdown menu: slider to move up/down maps does not work
Paulo van Breugel
p.vanbreugel at gmail.com
Sat Oct 6 04:08:12 PDT 2012
Sorry, the demo package is for wxPython, not Python.. so that agrees with
what I have on my system
On Sat, Oct 6, 2012 at 1:05 PM, Paulo van Breugel <p.vanbreugel at gmail.com>wrote:
> Hi,
> The TreeCtrl demo works. I can move up and down the folders with both the
> up and down keyboard key and the mouse (see screenshot for latter).
> Ubuntu 10.04 does not have the Unity interface yet I believe. My
> assumption was the problem is related to this. However, as said, the
> Maybe the following information is of use? GRASS is compiled with Python
> 2.7.3 and wxPython 2.8.12.1 (the demo package is Python 2.8 I see). I have
> compiled GRASS (both 6.4.3 and 7.0 from source, Python and wxPython are the
> default installs on Ubuntu 12.04)
> Cheers
> Paulo
>> not work
>> Reporter: pvanbosgeo | Owner: grass-dev@…
>> Type: defect | Status: new
>> Priority: major | Milestone: 6.4.3
>> Component: wxGUI | Version: svn-trunk
>> Keywords: map selection | Platform: Linux
>> Cpu: x86-64 |
>> Changes (by annakrat):
>> * keywords: => map selection
>> * component: Default => wxGUI
>> Comment:
>> Replying to [ticket:1759 pvanbosgeo]:
>> > When running GRASS (6.4 or 7.0) under Ubuntu (11.10 and 12.04), the
>> slider to move up/down in the dropdown list of maps does not work. It
>> does
>> appear (see attached screenshot), but when clicking on it it disappears.
>> Could you try the widget in wxpython demo (download
>> http://downloads.sourceforge.net/wxpython/wxPython-demo-2.8.12.1.tar.bz2
>> here]), it's the ComboCtrl widget, look for TreeCtrl popup. If it works
>> for you, there is some problem in the wxGUI code. For me (Ubuntu 10.04)
>> it
>> works fine.
>> > It is also not possible to move down or up the list with maps using the
>> keyboard arrow (should that be a feature request?). Thus, the only two
>> ways to select maps is by scrolling using the mouse wheel, or, when one
>> wants to select one map only, typing in the first letter(s) of the map
>> name.
>> Related ticket #1251
>> Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:1>
>> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121006/c2cdd464/attachment.html>
