[GRASS-dev] [GRASS GIS] #1756: V.Distance Command Problem
GRASS GIS trac at osgeo.org
Tue Oct 9 02:57:21 PDT 2012
  Reporter:  scorpionlegend92  |       Owner:  grass-dev@…
      Type:  defect            |      Status:  reopened
  Priority:  normal            |   Milestone:  6.4.3
 Component:  Default           |     Version:  6.4.2
Resolution:                    |    Keywords:  v.distance, attribute of nearest feature
  Platform:  MSWindows 7       |         Cpu:  Unspecified
Comment(by hellik):
 Replying to [comment:8 mlennert]:
 > > Please check and confirm.
 > I can't reproduce this. Using the NC demo data:
 > g.copy vect=hospitals,myhosp
 > v.distance from=myhosp to=myhosp upload=cat,dist,to_attr
 to_column=CANCER column=to_cat,dist,to_cancer table=my_test_table -a
 > works as expected both with dbf and sqlite backend, creating the table
 my_test_table with the three columns.
 > Can you try to reproduce with the NC data ?
 > If you have the very latest 6.4.3svn version installed, maybe this could
 be a specific windows issue ?
 tested here with osgeo4w-grass64-dev-6.4.3svn-r53339 and example above
 v.distance from=myhosp to=myhosp upload=cat,dist,to_attr to_column=CANCER
 1716 Kategorien mit mehr als einem Feature in der Vektorkarte <myhosp>.
 25600 Entfernungen berechnet.
 25600 Einträge eingefügt.
 v.distance komplett.
 (Tue Oct 09 11:54:48 2012) Command finished (1 sec)
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1756#comment:9>
