[GRASS-dev] vector network questions
Michael Barton
Michael.Barton at asu.edu
Wed Oct 10 15:25:16 PDT 2012
Markus,
Thanks. It is good that you did this. When teaching it, however, is when I can really find out what is more and less understandable. I'm trying to make some additional suggested enhancements to the documentation to make this complex but useful set of modules more accessible. I'll copy you along with Moritz and Markus.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 10, 2012, at 12:04 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> First of all, thanks for using GRASS network analysis tools in a
> course, Michael!
> I have updated the manual for v.net, explaining the different
> operation options in some more detail.
> I have updated the manuals of many of the v.net.* modules last year,
> testing and if necessary fixing bugs in the v.net.* modules.
> Apparently, my updates to the manuals were not sufficient for you. You
> object to the use of stdin pipes | which AFAICT work on Linux, Mac,
> and Windows. We can update the manuals to not use stdin pipes such
> that the creation of a text file in your favourite text editor is
> suggested first, then use this file as input for the modules affected.
> An IMHO more serious issue for GRASS 7 is the need to change the
> manuals to use examples from the North Carolina sample dataset, not
> from the spearfish dataset. But using e.g. streets_wake from the North
> Carolina sample dataset can cause out-of-memory errors in some v.net.*
> modules, for which there is no easy fix. The vector map roadsmajor is
> OTOH too simple to demonstrate GRASS vector network capabilities. We
> would need something like roadsmajor for all of North Carolina.
> Markus M
