[GRASS-dev] Moving v.pack and v.unpack from addons to trunk
Sören Gebbert soerengebbert at googlemail.com
Mon Oct 15 07:02:01 PDT 2012
Done in r53397.
I copied v.pack and v.unpack from the grass addons to trunk  and
removed them from the addons. I followed the howto  that is available
here:
http://trac.osgeo.org/grass/wiki/HowToSVN#MovingmodulesbetweentrunkandAddonsrepository
Best regards
Soeren
2012/8/27 Sören Gebbert <soerengebbert at googlemail.com>:
> Dear all,
> I would like to move v.pack and v.unpack from the grass7 addons repo
> into grass7 trunk. IMHO the functionality of these modules is really
> important to transfer grass vectors from one grass location into an
> other without conversion and information loss. The vector export
> modules v.pack and v.unpack are quite stable thanks to the great work
> of the grass developer Team around Markus Neteler, especially Luca
> Delucchi. In addition i have modified the modules to switch the
> compression on/off and added a test.
> The modules r.pack/r.unpack and v.pack/v.unpack are a core requirement
> of the space time raster and vector export/import modules in the
> temporal framework.
> I would like to move the modules next week if there are no objections
> against it.
> Any suggestions are welcome. :)
> Best regards
> Soeren
