[GRASS-dev] [GRASS-SVN] r53518 - grass/trunk/lib/temporal/lib
Markus Neteler neteler at osgeo.org
Sun Oct 21 09:14:37 PDT 2012
On Sun, Oct 21, 2012 at 3:56 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2012/10/21  <svn_grass at osgeo.org>:
>> Author: neteler
>> Date: 2012-10-20 23:39:16 -0700 (Sat, 20 Oct 2012)
>> New Revision: 53518
>> Modified:
>>    grass/trunk/lib/temporal/lib/default_name.c
>> Log:
>> fix debug level
>> -    G_debug(1,
>> +    G_debug(0,
>>             "Creating new default TGIS DB params with tgis_set_default_connection()");
> debug level 0 seems to be illegal.
Why this?
> Either use debug '1' or change G_debug() to G_message().
Then G_debug() doesn't make much sense to me.
Also
[neteler at north grass64]$ grep 'G_debug(0' */*/*.c
vector/v.perturb/myrng.c:       G_debug(0,"%g",numbers[i]);
[neteler at north grass64]$ grep 'G_debug(0' */*/*/*.c
lib/vector/Vlib/dgraph.c:              G_debug(0, "exact=%d orig=%d",
res, res2);
vector/lidar/v.lidar.growing/ConvexHull.c:    G_debug(0, "run-time error...");
vector/lidar/v.lidar.growing/ConvexHull.c:    G_debug(0, "%s", error_text);
vector/v.lrs/v.lrs.label/main.c:        G_debug(0, "  line = %d / %d",
line, nlines);
vector/v.lrs/v.lrs.label/main.c:        G_debug(0, "    %d reference
segments selected", nrseg);
[neteler at north grass70]$ grep 'G_debug(0' */*/*.c
display/d.vect/label.c: G_debug(0, "ncentroids (ogr) = %d", nlines);
lib/gis/token.c:     G_debug(0, "%d=[%s]", i, tokens[i]);
raster3d/r3.in.ascii/main.c:                        G_debug(0,
"invalid value at col=%d row=%d depth=%d last_value=[%s]",
vector/v.lidar.growing/ConvexHull.c:    G_debug(0, "run-time error...");
vector/v.lidar.growing/ConvexHull.c:    G_debug(0, "%s", error_text);
It is not usual at least...
Markus
