[GRASS-dev] how to change areas to lines and keep attributes
Moritz Lennert mlennert at club.worldonline.be
Wed Oct 24 00:20:17 PDT 2012
On 23/10/12 19:21, Michael Barton wrote:
> Any suggestions how to transform areas to boundary/lines AND attach the
> original area attributes?
Which attribute would you attach to a boundary common to two areas ?
> My goal is to color the boundaries of areas
> according to the value of an attribute, while leaving the fill transparent.
Why don't you just do that directly with areas using d.vect col=
fcol=none where= ?
Moritz
