[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
GRASS GIS trac at osgeo.org
Thu Oct 25 00:00:53 PDT 2012
 Reporter:  martinl                                 |       Owner:  grass-dev@…
     Type:  defect                                  |      Status:  new
 Priority:  normal                                  |   Milestone:  6.4.2
Component:  wxGUI                                   |     Version:  unspecified
 Keywords:  cartographic composer, psmap, wingrass  |    Platform:  MSWindows XP
      Cpu:  Unspecified                             |
Comment(by annakrat):
 There are a few problems:
 * Ghostscript is missing (not in OSGeo4W framework)
 * if it is installed it is not on the PATH
 * from the PIL source code (C:\OSGeo4W\apps\Python27\Lib\site-
 packages\PIL\EpsImagePlugin.py):
 def Ghostscript(tile, size, fp):
     """Render an image using Ghostscript (Unix only)"""
     command = ["gs",
                "-q",                    # quite mode
                "-g%dx%d" % size,        # set output geometry (pixels)
                "-dNOPAUSE -dSAFER",     # don't pause between pages, safe
 mode
                "-sDEVICE=ppmraw",       # ppm driver
                "-sOutputFile=%s" % file,# output file
                "- >/dev/null 2>/dev/null"]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1554#comment:5>
