[GRASS-dev] composer preview
Anna Kratochvílová kratochanna at gmail.com
Fri Oct 26 00:43:38 PDT 2012
On Fri, Oct 26, 2012 at 12:23 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
> So that was easier to test than I thought. I had not reinstalled X11 on one of my computers since updating to OS X 10.8. Even with PIL installed, here is what happens:
> 1. When I click the preview button, I get the following screen.
> If I click "continue" it takes me to the XQuartz project site to install XQuartz. If I click cancel, I get the following error:
> So this is a PIL/Ghostscript/X11 issue. Note that Ghostscript IS installed on my Mac by default.
> After installing a XQuartz, the composer preview works. This is not a huge problem on the Mac then, but it seems like people should not need to install X11 solely for converting pdf2png. No other way?
I don't know how Ghostscript handles PostScript and why is X11 needed.
And I can't see any way to change it.
Anna
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Oct 25, 2012, at 1:13 PM, Anna Kratochvílová <kratochanna at gmail.com>
>  wrote:
> On Thu, Oct 25, 2012 at 6:49 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> Anna,
> I am happy to test. But composer preview has worked for me in the past once I installed PIL. I do have Ghostscript. I installed it manually long ago, but I'm pretty sure that it comes with the Mac OS these days.
> I thougt the preview was not working for you because of the ticket
> [1]. If it is working there is probably nothing to test.
> Thanks anyway,
> Anna
> [1] http://trac.osgeo.org/grass/ticket/1715
> Michael
> C. Michael Barton
> On Oct 25, 2012, at 12:11 AM, Anna Kratochvílová <kratochanna at gmail.com>
> wrote:
> Hi Michael,
> could you do a test for me with the cartographic composer? The preview
> can be broken for several reasons [1]. Could you check that you have
> Ghostscript installed? Then, if you have it, try if it is on the PATH.
> If not, could you put it on the PATH? Then it could work on Mac. But
> there is probably no chance to make it work on Windows.
> Thanks,
> Anna
> [1] http://trac.osgeo.org/grass/ticket/1554#comment:5
