[GRASS-dev] [GRASS GIS] #1776: Python error by startup
GRASS GIS trac at osgeo.org
Tue Oct 30 12:48:23 PDT 2012
 Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Default     |     Version:  svn-trunk
 Keywords:              |    Platform:  Linux
      Cpu:  x86-64      |
 Hi, I just compiled / build GRASS 7.0 from source and got the following
 error message when starting up GRASS:
 Popup 'Python error':
 Cannot set locale to ".
 Messages on command line:
 Failed to set LC_ALL to None.UTF-8
 (process:14771): Gdk-WARNING **: locale not supported by C library
 (process:14771): Gtk-WARNING **: Locale not supported by C library.
         Using the fallback 'C' locale.
 These messages appear twice; directly at start up and then again when the
 Layer manager and Display open.
 My system information:
 GRASS version: 7.0.svn
 GRASS SVN Revision: 53615
 GIS Library Revision: 52468 (2012-07-27)
 GDAL/OGR: 1.9.2
 PROJ4: Rel. 4.7.1, 23 September 2009
 Python: 2.7.3
 wxPython: 2.8.12.1
 Platform: Linux-3.5.0-17-generic-x86_64-with-Ubuntu-12.10-quantal
Ticket URL: <http://trac.osgeo.org/grass/ticket/1776>
