[GRASS-dev] installing r.modis fails
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Oct 31 04:20:57 PDT 2012
Hi Luca
Thanks for looking into this. I answered your request for the ticket on
the locale. I should perhaps add though that I was not able to install
r.modis in an earlier revision of GRASS 7.0 either, while the locale
error messages only started with the current revision (which I compiled
after upgrading to Ubuntu 12.10, so perhaps that has broken something
concerning the locale?).
Cheers,
Paulo
On 10/31/2012 11:41 AM, Luca Delucchi wrote:
> 2012/10/31 Paulo van Breugel <p.vanbreugel at gmail.com>:
>> Hi, I am trying to install r.modis using g.extension, which gives me the
>> error messages below. Note that the first three svn warnings also showed up
>> during compiling GRASS (reported here:
>> http://trac.osgeo.org/grass/ticket/1776) and with any extension I install.
>> So they are probably not related to the problem with installing r.modis
>> Fetching <r.modis> from GRASS-Addons SVN (be patient)...
>> svn: warning: cannot set LC_CTYPE locale
>> svn: warning: environment variable LC_CTYPE is en_US
>> svn: warning: please check that your locale name is correct
>> Compiling...
>> ERROR: modis library not imported
>> make[1]: *** [r.modis.download.tmp.html] Error 1
>> ERROR: rmodislib library not imported
>> make[1]: *** [r.modis.import.tmp.html] Error 1
>> Installing...
>> /usr/bin/install: cannot stat
>> `/home/paulo/Data/GRASSdb/latlon/PERMANENT/.tmp/paulo-HP-Z60
>> 0-Workstation/5191.0/r.modis/docs/html/r.modis.download.html
>> ': No such file or directory
>> make[1]: *** [install] Error 1
>> 0-Workstation/5191.0/r.modis/docs/html/r.modis.import.html':
>> ERROR: Unable to read manual page: [Errno 2] No such file or directory:
>> '/home/paulo/.grass7/addons/docs/html/r.modis.html'
> so, here there is a problem related to r.modis libraries, I should use
> 'pass' in a try exceptions but I don't like so much because if the
> libraries are missing no errors are returned during running
>> I seems r.modis is installed, but running the command r.modis.download gives
>> me the warning message:
>> Unable to fetch interface description for command 'r.modis.download'.
>> Details:
>> GRASS_INFO_ERROR(5384,1): modis library not imported
>> GRASS_INFO_END(5384,1)
> this seem related to your ticket, and this is related to your locale situation.
> I added a request to that ticket
>> Best regards,
>> Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121031/3b3ef561/attachment.html>
