[GRASS-dev] v.net.allpairs seems broken
Michael Barton Michael.Barton at asu.edu
Wed Oct 31 14:35:35 PDT 2012
Excellent!
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Oct 31, 2012, at 2:29 PM, Markus Metz <markus.metz.giswork at gmail.com>
 wrote:
> On Mon, Oct 15, 2012 at 5:11 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
>> On Mon, Oct 15, 2012 at 4:34 PM, Michael Barton <Michael.Barton at asu.edu>
>> wrote:
>>> One thing that is confusing is that the text for both entries alayer and
>>> nlayer shows up as "Layer number or name" instead of the text that is
>>> actually in the description field "Arc layer" and "Node layer". Any idea why
>>> this is so?
>> The label for the standard option G_OPT_V_FIELD is by default set to "Layer
>> number or name", and the label, if set, is used as text next to the option
>> key. Having "Arc layer" or "Node layer" next to the key can be easily done
>> be making "Arc layer" or "Node layer" option labels, which should then be
>> done for all v.net.* modules.
> Done for trunk in r53630.
> Markus M
