[GRASS-dev] [GRASS GIS] #1720: r.viewshed doesn't compile in GRASS 7
GRASS GIS trac at osgeo.org
Tue Sep 4 18:57:22 PDT 2012
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Compiling    |     Version:  svn-trunk
 Keywords:  r.viewshed   |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [comment:4 cmbarton]:
 > I was wrong about adding --with-CXX=/usr/bin/g++ to my configure string.
 That doesn't switch compilers in platform.make.
 A specific C++ compiler can be forced by setting the CXX environment
 variable, e.g.
 CXX=/usr/bin/g++ ./configure ...
 Similarly, CC, CPPFLAGS, CFLAGS, CXXFLAGS, and LDFLAGS can be set via
 environment variables; the configure script won't auto-detect the setting
 if the environment variable exists.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1720#comment:6>
