[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
GRASS GIS trac at osgeo.org
Thu Sep 6 15:20:39 PDT 2012
 Reporter:  hamish                   |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  critical                 |   Milestone:  6.4.3
Component:  Projections/Datums       |     Version:  svn-releasebranch64
 Keywords:  location wizard, g.proj  |    Platform:  All
      Cpu:  All                      |
Changes (by neteler):
  * milestone:  6.4.2 => 6.4.3
Comment:
 Is this still a problem? I have tested EPSG 3003 (an Italy code) with
 6.4.2 and
 proj-4.7.0-5.fc17.x86_64, it properly suggest the available datums in the
 location
 wizard.
 Also on command line it works:
 GRASS 6.4.3svn (newLocation):~ > g.proj epsg=3003 datumtrans=-1
 1
 Used in whole rome40 region
 towgs84=-225.000,-65.000,9.000
 4
 Used in Italy (Sicily)
 towgs84=-50.2,-50.4,84.8,-0.690,-2.012,0.459,-28.08
 Accuracy 3-4m
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:15>
