[GRASS-dev] [GRASS GIS] #1721: Man pages not created for addons
GRASS GIS trac at osgeo.org
Fri Sep 7 12:49:56 PDT 2012
  Reporter:  micha        |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  6.4.3
 Component:  Addons       |     Version:  6.4.2
Resolution:  fixed        |    Keywords:  install, g.html2man
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by micha):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I see what my problem was. I (mis)read the instructions from
 [http://grass.osgeo.org/wiki/Compile_and_Install#Addons] . I understood
 that MODULE_TOPDIR should refer to the top of the grass installation. Now,
 from you comments, I see it needs to be the directory where source is
 located. When I changed the procedure to:
 make MODULE_TOPDIR=~/Downloads/grass-6.4.2/
 sudo make  MODULE_TOPDIR=~/Downloads/grass-6.4.2/ install
 it worked fine.
 Maybe the compile and install wiki page should explicitly mention
 "/path/to/unpacked/grass/source"?
 Sorry for the noise, and thanks for the help.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1721#comment:5>
