[GRASS-dev] winGRASS 6.4.svn: Attribute manager not opening
Anna Kratochvílová kratochanna at gmail.com
Sun Sep 9 07:53:14 PDT 2012
On Sun, Sep 9, 2012 at 1:15 PM, Hamish <hamish_b at yahoo.com> wrote:
> Hi,
> does this have to do with parsing the vector/$MAP/dbln file?
> There was an unfortunate thing in the 6.x format spec of that file where
> space was used as the delimiter and it was impossible to fix for spaces
> in the path, since the result would always be ambiguous. In GRASS 7 I
> changed the delim to '|', and AFAIR backported read-support for that back
> to grass6. If that sounds like the issue let me know and I'll dig out
> more details about it, and how to work around it so it works cleanly
> in all branches in a backwarks-forwards compatible way.
> Note that for the dbln file the C code looks for and substitutes for
>   $GISDBASE/$LOCATION_NAME/$MAPSET/
> on all platforms, they are simulated enviro variables and for file-
> system portability should be kept in the above form instead of replacing
> with a real path. (unless that's really what you want to do)
This doesn't seem related. I explained the problem in the mail above
but I can try to explain it more clearly if needed.
>> I recently added the fs parameter to be able to open data
>> which contain | character by changing the separator in
>> preferences.
> sorry, this email thread got lost in the pile. where/what specifically
> are you talking about there?
Here is the ticket:
http://trac.osgeo.org/grass/ticket/1633
Anna
> Hamish
> [sorry for the top posting, broken linewrap, and missing authors, too
> late to fight with yahoo tonight]
>> > when loading "roadsmajor" of NC on various windows
>> machines (with
>> > and without white space in the grassdata path, we get
>> > Error:
>> > 'columns' is not recognized as an internal or external
>> command,
>> > operable program or batch file
>> > [OK]
>> > Then the attrib. manager opens but it remains empty.
>> > Maybe here?
>> > dbmgr/manager.py
>> self.listOfCommands.append(('v.db.addcol',
>>      { 'map'     :
>> self.vectorName,
>>        'layer'   :
>> self.layer,
>>        'columns' : '%s %s' % (name,
>> ctype) }
>> > No idea..
>> > Markus
>> Problem occurs when calling this (line 194, dbmgr/manager.py
>> in grass64)
>> ret = RunCommand('v.db.select',
>>    quiet = True,
>>    parent = self,
>>    flags = 'c',
>>    map = self.mapDBInfo.map,
>>    layer = layer,
>>    columns = ','.join(columns),
>>    fs = fs,
>>    where = where,
>>    stdout = outFile)
>> preferences. On
>> Windows it is causing splitting the whole command into 2
>> parts -
>> before and after pipe. As a result 'columns' parameter
>> (after pipe) is
>> treated like another command. As a temporal workaround you
>> can set the
>> separator to something different in preferences (more
>> characters are
>> accepted)  - this should work immediately. I can also
>> revert the
>> change.
>> On Linux the characters in parameters are escaped properly
>> probably in
>> Popen but not on Windows. Anyone knows how to solve this
>> properly?
