[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Mon Sep 10 01:59:29 PDT 2012
 Reporter:  antonioall  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.in.lines  |    Platform:  MSWindows 7
      Cpu:  x86-64      |
Description changed by neteler:
Old description:
> Hello,
> The file Coordinate.txt is:
> 496174.445494,4553975.166661,429.9415
> 495577.433542,4556363.214470,372.9797
> NaN,NaN,NaN
> 497882.563024,4554290.256303,370.0215
> NaN,NaN,NaN
> NaN,NaN,NaN
> 497899.146689,4556479.300127,382.7335
> NaN,NaN,NaN
> NaN,NaN,NaN
> The Text of Error is:
> (Mon Sep 10 10:44:48 2012)
> v.in.lines -z input=C:\myPATH\Coordinate.txt output=prova fs=,
> C:/GRASS GIS 6.4.3svn/scripts/v.in.lines: line 108:
> /otherMyPath/PERMANENT/.tmp/4520.0: No such file or
> directory
> head: cannot open `/otherMyPath/PERMANENT/.tmp/4520.0' for reading: No
> such file or directory
> ERROR: Not enough data columns. (incorrect fs setting?)
> (Mon Sep 10 10:44:48 2012) Comando terminato (0 sec)
> Thanks,
> Best regards
New description:
 Hello,
 NaN,NaN,NaN
 NaN,NaN,NaN
 NaN,NaN,NaN
 NaN,NaN,NaN
 NaN,NaN,NaN
 directory
 Thanks,
 Best regards
Ticket URL: <http://trac.osgeo.org/grass/ticket/1727#comment:1>
