[GRASS-dev] load 3d-vector in 3d-view mode fails in wingrass
Helmut Kudrnovsky hellik at web.de
Wed Sep 12 03:28:54 PDT 2012
tested with osgeo4w-wingrass6.5.svn/6.4.3svn and slovakia3d-data set:
g.region -p vect=precip3d at PERMANENT
projection: 0 (x,y)
zone:       0
north:      5492305
south:      5294826
west:       4193437
east:       4603765
nsres:      499.94683544
ewres:      499.79049939
rows:       395
cols:       821
cells:      324295
v.info map=precip3d at PERMANENT
 | Layer:           precip3d at PERMANENT
 | Mapset:          PERMANENT
 | Datenbank:       \grassdata
 | Titel:
 | Maßstab:       1:1
 | Kartenformat:      native
 | Name des Erzeugers:
 | Organisation:
 | Quelldatum:
 |   Typ der Karte:  Vektor (Level: 2)
 |   Anzahl Punkte:       435             Anzahl Flächen:      0
 |   Anzahl Linien:        0               Anzahl Inseln:    0
 |   Anzhal Grenzen:   0               Anzahl faces:      0
 |   Anzahl Zentroid:    0               Anzahl Kerne:    0
 |   Karte ist 3D:              Yes
 |   Anzahl der dblinks:      1
 |         Projektion: Unbekannte Projektion.
 |               N:           5492305    S:           5294826
 |               E:           4603765    W:           4193437
 |               B:                95    T:              1900
 |   Digitalisierungs-Schwellwert: 0
 |   Kommentare:
 Starting 3D view mode...
  File "C:\OSGeo4W\apps\grass\grass-6.4.3svn\etc\wxpython\ma
pdisp\toolbars.py", line 229, in OnSelectTool
self.parent.AddNviz()
pdisp\frame.py", line 322, in AddNviz
self._layerManager.AddNvizTools()
  File "C:\OSGeo4W\apps\grass\grass-6.4.3svn\etc\wxpython\lm
gr\frame.py", line 299, in AddNvizTools
display = self.curr_page.maptree.GetMapDisplay())
  File "C:\OSGeo4W\apps\grass\grass-6.4.3svn\etc\wxpython\nv
iz\tools.py", line 100, in __init__
self.UpdateSettings()
iz\tools.py", line 2563, in UpdateSettings
value = int(self.mapWindow.iview[control]['value'])
ValueError
cannot convert float NaN to integer
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/load-3d-vector-in-3d-view-mode-fails-in-wingrass-tp5001406.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
