[GRASS-dev] Grass SVN in Android, display issue
Chemin, Yann (IWMI) Y.Chemin at cgiar.org
Mon Sep 17 20:37:09 PDT 2012
Hi Markus,
Rooted the Android 4.0.3, installed an Ubuntu arm img, apt-get update, apt-get install grass-dev, apt-get install <additional GRASS dep>, svn co trunk , conf, make, make install, (compiled required stuff within the img Linux CLI), got stuck with GUI, but eventually all went well as androidVNC has a Send Key button (ctrl+shift+t calls the terminal in Ubuntu, then it is as usual: grass70 is responding well).
On Archos 80 g9 Turbo (dual-core) I thought make -j2 would do it, bad idea, /tmp gets flooded and just refuses files with a no space left warning.
Would like to indulge in your version of things, let us speak a bit off ML. However, there will be a problem: GUI.
wxPython is not even close to alpha release on Android. So it will be a problem down the road.
Why GRASS GIS on Android? For fun first, for work later. Did learn few things on the way, that was fun. I needed a half Kg programming machine for on-the-road GRASS/GDAL stuff with OpenMP, thought that if GRASS would compile its trunk in one way or another in that dual-core Android, then I would be keeping the device and ditch nettop/micro-laptop etc...
Cheers,
Yann
________________________________________
From: neteler.osgeo at gmail.com [neteler.osgeo at gmail.com] on behalf of Markus Neteler [neteler at osgeo.org]
Sent: Tuesday, September 18, 2012 2:25 AM
To: Chemin, Yann (IWMI)
Cc: GRASS developers list
Subject: Re: [GRASS-dev] Grass SVN in Android, display issue
On Mon, Sep 17, 2012 at 5:47 AM, Chemin, Yann (IWMI) <Y.Chemin at cgiar.org> wrote:
> Hi all,
> I am looking for ways to display wxGUI of GRASS (trunk version) in Android.
Just curious: did you compile GRASS 7 on Android?
I just tried with a cross compiled
(arm-gp2x-linux-gcc-c++-4.1.2-13.fc17.x86_64),
using Marco Bernasocchi build scripts from QGIS
and got quite a bit compiled.
A few issues are in the library part:
ls.c: In function 'G_ls_format':
ls.c:173: error: storage size of 'size' isn't known
make[3]: *** [OBJ.arm-unknown-linux-androideabi/ls.o] Error 1
make[3]: Leaving directory `/home/neteler/grass70/lib/gis'
--> use #ifdef __ANDROID__ ?
Then:
cd OBJ.arm-unknown-linux-androideabi &&
GISRC=/home/neteler/grass70/dist.arm-unknown-linux-androideabi/demolocation/.grassrc70
GISBASE=/home/neteler/grass70/dist.arm-unknown-linux-androideabi
PATH="/home/neteler/grass70/dist.arm-unknown-linux-androideabi/bin:/home/neteler/grass70/dist.arm-unknown-linux-androideabi/bin:$PATH"
PYTHONPATH="/home/neteler/grass70/dist.arm-unknown-linux-androideabi/etc/python:/home/neteler/grass70/dist.arm-unknown-linux-androideabi/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/home/neteler/grass70/dist.arm-unknown-linux-androideabi/bin:/home/neteler/grass70/dist.arm-unknown-linux-androideabi/lib:/home/neteler/grass70/dist.arm-unknown-linux-androideabi/lib:"
LC_ALL=C ./test
/bin/sh: ./test: cannot execute binary file
make[5]: *** [OBJ.arm-unknown-linux-androideabi/test.tmp] Error 126
make[5]: Leaving directory `/home/neteler/grass70/lib/vector/diglib'
Some Makefile issues:
rm -f /home/neteler/grass70/dist.arm-unknown-linux-androideabi/etc/VERSIONNUMBER
/usr/bin/install -c  prompt.py
/home/neteler/grass70/dist.arm-unknown-linux-androideabi/etc/prompt.py
make[3]: *** No rule to make target
`/home/neteler/grass70/dist.arm-unknown-linux-androideabi/docs/html/help_loc_struct.png',
needed by `default'.  Stop.
make[3]: *** Waiting for unfinished jobs....
chmod +r /home/neteler/grass70/dist.arm-unknown-linux-androideabi/etc/VERSIONNUMBER
chmod +r /home/neteler/grass70/dist.arm-unknown-linux-androideabi/etc/license
make[3]: Leaving directory `/home/neteler/grass70/lib/init'
test -d OBJ.arm-unknown-linux-androideabi || mkdir -p
make[4]: *** No rule to make target
`/home/neteler/grass70/dist.arm-unknown-linux-androideabi/docs/html/grass-dbf.html',
needed by `db_html'.  Stop.
make[4]: *** Waiting for unfinished jobs....
make[4]: Leaving directory `/home/neteler/grass70/db/drivers/dbf'
`/home/neteler/grass70/dist.arm-unknown-linux-androideabi/docs/html/grass-ogr.html',
make[4]: Leaving directory `/home/neteler/grass70/db/drivers/ogr'
Eventually I didn't get the link to PROJ4 right, so subsequent compilation
of modules depending on that naturally fails. But I didn't spend time on
this.
Not sure how to solve above issues:
Markus
PS: Maybe it is useless to run GRASS on Android but maybe not.. :)
