[GRASS-dev] Grass SVN in Android, display issue
Wed Sep 19 07:22:28 PDT 2012
Glynn Clements wrote:
> Currently, the configure script shouldn't abort if it can't find the
> XDR functions. If you remove the AC_MSG_ERROR, you need to add XDRLIB=
> so that it's always defined.
That should have said "... should abort if ...".
> > So, a high percentage of the GRASS modules do compile now (186
> > compiled, 34 fail, most of them due to the G3D lib XDR issue).
> I'll look into the G3D XDR issue.
Can someone test the attached patch? Not necessarily on Android; the
first priority is ensuring that it doesn't break anything on existing
platforms.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120919/1430d598/attachment-0001.ksh>
