[GRASS-dev] GRASS6.4.3svn d.his maps from different mapsets
Helena Mitasova hmitaso at ncsu.edu
Wed Sep 19 20:37:45 PDT 2012
It appears that d.his does not work when the map layers are from different mapsets,
the following command which has the first map in PERMANENT and the second one in mea582f2012
expects both maps in PERMANENT
d.his i_map=elevation_shade h_map=noise bright=30
Command 'd.his bright=30 i_map=elevation_shade at PERMANENT
h_map=noise at PERMANENT' failed
Details: Raster map <noise at PERMANENT> not found
adding the mapset to the name did not help, I was still getting the error for the following:
d.his h_map=noise at mea582f2012 i_map=elevation_shade at PERMANENT bright=30
d.his i_map=elevation_shade at PERMANENT h_map=noise at mea582f2012 bright=30
It runs OK from GUI.
Can somebody try this out independently?
I can file a bug report but I would like to make sure that this is not my local problem,
Thanks, Helena
Helena Mitasova
Associate Professor
Department of Marine, Earth, and Atmospheric Sciences
2800 Faucette Drive, Rm. 1125 Jordan Hall
North Carolina State University
Raleigh, NC 27695-8208
hmitaso at ncsu.edu
"All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
On Sep 19, 2012, at 3:02 AM, Anna Kratochvílová wrote:
> Hi,
> sorry for the late answer,
> On Tue, Sep 11, 2012 at 4:26 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
>> Anna,
>> here is a more complete information:
>> this is what I typed in and running it resulted in the error message below
>> d.vect -c basin_50Kval
> for me it works. I try for example
> d.vect -c railroads
> and the layer is added correctly and arrow up shows you
> d.vect -c map=railroads at PERMANENT
> There shouldn't be any platform specific code so I don't understand
> why it's not working. I tested it for both grass 6.4 and 7. Is it
> still an issue?
> Anna
>> if you try to rerun it by retrieving it from history using up arrow it shows this (apparently that is what I sent without checking it)
>> d.vect map=-c basin_50Kval
>> it works with the word map
>> d.vect -c map=basin_50Kval
>> or if -c is at the end
>> d.vect map=basin_50Kval -c
>> so it unfortunately does the same thing as d.rast,
>> Helena
>> On Sep 10, 2012, at 3:17 AM, Anna Kratochvílová wrote:
>>> On Mon, Sep 10, 2012 at 3:09 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
>>>>>> d.rast -o landuse96_28m cat=1,2
>>>>>> run in command console is interpreted as follows:
>>>>>> Command 'd.rast -l -a -n -d -u -s -e -9 -6 -_ -2 -8 -m
>>>>>> map=-o cat=1,2' failed
>>>>>> Details: Sorry, <l> is not a valid flag
>>>>>> Sorry, <a> is not a valid flag
>>>>>> Sorry, <n> is not a valid flag
>>>>>> Sorry, <d> is not a valid flag
>>>>>> Sorry, <u> is not a valid flag
>>>>>> Sorry, <s> is not a valid flag
>>>>>> Sorry, <e> is not a valid flag
>>>>>> Sorry, <9> is not a valid flag
>>>>>> Sorry, <6> is not a valid flag
>>>>>> Sorry, <_> is not a valid flag
>>>>>> Sorry, <2> is not a valid flag
>>>>>> Sorry, <8> is not a valid flag
>>>>>> Sorry, <m> is not a valid flag
>>>>>> d.rast landuse96_28m cat=1,2 -o works fine.
>>>>> I tried to fix it so it should work now. I hope I didn't break
>>>>> something else, this is quite difficult to test.
>>>> does this fix solve also the flags with d.vect? For example I get
>>> This should probably be  d.vect -c  map=basin_50Kval? This case works.
>>> "d.vect map=-c basin_50Kval" is bad input and it would be difficult to
>>> handle  all wrong inputs.
>>>>> Command 'd.vect -b -a -s -i -n -_ -5 -0 -K -v -a -l map=-c'
>>>>> failed
>>>>> Details: Sorry, <b> is not a valid flag
>>>>> Sorry, <5> is not a valid flag
>>>>> Sorry, <0> is not a valid flag
>>>>> Sorry, <K> is not a valid flag
>>>> Thanks a lot.
>>>> I think I have written that the color fill on cutting planes does not work on windows - I tried it again and it works great,
>>>> We just worked in class with wxnviz last week and we did not have any problems on 20+ computers and laptops
>>>> running windows and Mac OSX, so that is fantastic, given how new the GUI is.
>>> I'm glad to hear that.
>>>> Also, this is the first year that I haven't seen many complaints about import/export of raster and vector data,
>>>> so that is a great improvement too.
>>>> The only comment I have seen so far was lack of Browse button when selecting the directory for v.out.ogr output,
>>>> I am wondering whether it is intentional due to some technical issues or just an oversight,
>>>> given that r.out.gdal has such option.
>>> I don't know, the gui respects that the dsn option is string and not
>>> file. There is probably some difference but someone would know this
>>> better.
>>> Anna
>>>> Helena
>>>>>> add volume still does not open dialog
>>>>> Maybe someone else (who is more familiar with PATH and Makefiles) could help?
>>>>> Anna
>>>>>> I am running Michaels Mac binary,
>>>>>> Helena
>>>>>> Helena Mitasova
>>>>>> Associate Professor
>>>>>> hmitaso at ncsu.edu
>>>>>> _______________________________________________
>>>>>> grass-dev mailing list
>>>>>> grass-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
