[GRASS-dev] GRASS scripting Python API error/fatal handling
Sun Sep 30 15:33:34 PDT 2012
Sören Gebbert wrote:
> > For simple clean-up operations, atexit.register() is sufficient.
> While implementing this, can we use the "raise_on_error" flag to
> enable the raise of a ScriptError exception in fatal()?
> It would be only a simple modification of the current code i guess.
Yes. The only thing which needs to be done is to move the conditional
from error() to fatal(), and check any code which might be using
set_raise_on_error() in case it relies upon the existing behaviour.
Most scripts should continue to use atexit.register() for clean-up and
not bother with exception handling.
