[GRASS-dev] r.fillnulls failure (grass7 )
epi massimodisasha at gmail.com
Sat Apr 6 07:25:10 PDT 2013
epy at epinux:~/dev/grass_trunk$ svn up
Updating '.':
At revision 55645.
GRASS 7.0.svn (utm19N_wgs84):~ > g.region rast=dtm1 -ap
projection: 1 (UTM)
zone:       19
datum:      wgs84
ellipsoid:  wgs84
north:      4720170
south:      4715050
west:       391340
east:       398580
nsres:      10
ewres:      10
rows:       512
cols:       724
cells:      370688
GRASS 7.0.svn (utm19N_wgs84):~ > r.fillnulls input=dtm1 output=dtm1 --overwrite
Using RST interpolation...
Locating and isolating NULL areas...
 100%
Growing NULL areas
Assigning IDs to NULL areas
 100%
Processing 1 map holes
Filling hole 2 of 1
 100%
 100%
 100%
Note: The following warnings about number of points for interpolation may
be ignored.
ERROR: Database connection not defined for layer 1
ERROR: Failed to fill hole 2
WARNING: Raster map <r_fillnulls_5883_hole_2_dem> not found
WARNING: <r_fillnulls_5883_hole_2_dem> nothing removed
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130406/436f5a27/attachment-0001.html>
