[GRASS-dev] r.fillnulls failure (grass7 )
Markus Neteler neteler at osgeo.org
Sun Apr 7 13:47:15 PDT 2013
On Sat, Apr 6, 2013 at 5:15 PM, epi <massimodisasha at gmail.com> wrote:
> GRASS 7.0.svn (utm19N_wgs84):/home/epy > r.fillnulls input=dtm1 output=dtm1fill --overwrite
> Using RST interpolation...
> Locating and isolating NULL areas...
>  100%
> Growing NULL areas
> Assigning IDs to NULL areas
>  100%
> Processing 1 map holes
> Filling hole 2 of 1
... this looks odd
>  100%
>  100%
>  100%
> Note: The following warnings about number of points for interpolation may
> be ignored.
> ERROR: Database connection not defined for layer 1
^^^- same problem here (I tried the example in the manual page
which fails - a bug (or two).
Markus
