[GRASS-dev] [GRASS GIS] #1586: v.in.wfs complains about xerces-c support in GDAL
GRASS GIS trac at osgeo.org
Sat Apr 13 08:29:19 PDT 2013
 Reporter:  alf                 |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.3
Component:  Vector              |     Version:  svn-releasebranch64
 Keywords:  wingrass, v.in.wfs  |    Platform:  MSWindows Vista
      Cpu:  Unspecified         |
Comment(by mmetz):
 Replying to [comment:8 neteler]:
 > New debugging: As a start on Linux:
 > Test on downloaded XML file (attached to this ticket for inspection):
 GRASS 6.4.3svn (latlong):/tmp > v.in.ogr 8822.0.xml out=cities_1m
 Projection of input dataset and current location appear to match
 Layer: geonam_gt1M
 WARNING: Width for column gml_id set to 255 (was not specified by OGR),
          some strings may be truncated!
 WARNING: DBMI-DBF driver: column name 'alternatenames' truncated to
          'alternaten'
 WARNING: DBMI-DBF driver: column name 'featureclass' truncated to
          'featurecla'
 WARNING: DBMI-DBF driver: column name 'featurecode' truncated to
          'featurecod'
 WARNING: DBMI-DBF driver: column name 'countrycode' truncated to
          'countrycod'
 WARNING: DBMI-DBF driver: column name 'modificationdate' truncated to
          'modificati'
 Counting polygons for 206 features...
 Importing map 206 features...
 Segmentation fault (core dumped)
 ogrinfo --version
 GDAL 1.9.1, released 2012/05/15
 Works for me on Linux with GRASS 6.4.3svn and GDAL 1.9.2, released
 2012/10/08.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1586#comment:9>
