[GRASS-dev] [GRASS GIS] #1827: Measure Distance - Bearing
GRASS GIS trac at osgeo.org
Sun Apr 14 20:17:50 PDT 2013
  Reporter:  voncasec  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  6.4.3
 Component:  wxGUI     |     Version:  svn-releasebranch64
Resolution:  fixed     |    Keywords:  Bearing tool, MapFrame.MeasureDist()
  Platform:  Linux     |         Cpu:  x86-64
Comment(by hamish):
 Replying to [comment:2 hamish]:
 > I wonder for LL if we should have frame.py check for meters as the unit,
 > and report km instead if the distance is > 2500.0?
 ah, I see that MapFrame.FormatDist() already tries to do that, but it
 fails for LL as the fn is testing against the map units from projinfo
 (which says degrees) while the fn is being used with results from
 G_distance() which always returns meters.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1827#comment:3>
