[GRASS-dev] [GRASS GIS] #854: g.extension does not work on a Mac (probably not on Windows either
GRASS GIS trac at osgeo.org
Thu Apr 18 11:22:29 PDT 2013
 Reporter:  cmbarton             |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  6.4.3
Component:  Addons               |     Version:  svn-releasebranch64
 Keywords:  g.extension, addons  |    Platform:  All
      Cpu:  All                  |
Comment(by cmbarton):
 I just compiled GRASS 7 in the past couple hours. g.extension still does
 not seem to work. I randomly tried to install i.rotate from the addons
 site using the addons interface in the GUI. Here is the result:
 g.extension extension=i.rotate svnurl=http://svn.osgeo.org/grass/grass-
 addons/grass7
 Fetching <i.rotate> from GRASS-Addons SVN (be patient)...
 Compiling...
 main.c:16:31: error: grass/config.h: No such file or
 directory
 main.c:23:23: error: grass/gis.h: No such file or directory
 main.c:24:26: error: grass/raster.h: No such file or
 directory
 main.c:25:29: error: grass/gprojects.h: No such file or
 directory
 main.c:26:27: error: grass/glocale.h: No such file or
 directory
 main.c: In function 'main':
 main.c:43: error: storage size of 'history' isn't known
 main.c:49: warning: assignment makes pointer from integer
 without a cast
 main.c:53: error: dereferencing pointer to incomplete type
 main.c:57: error: 'G_OPT_R_INPUT' undeclared (first use in
 this function)
 main.c:57: error: (Each undeclared identifier is reported
 only once
 main.c:57: error: for each function it appears in.)
 main.c:57: warning: assignment makes pointer from integer
 without a cast
 main.c:58: error: 'G_OPT_R_OUTPUT' undeclared (first use in
 this function)
 main.c:58: warning: assignment makes pointer from integer
 without a cast
 main.c:59: warning: assignment makes pointer from integer
 without a cast
 main.c:60: error: dereferencing pointer to incomplete type
 main.c:61: error: dereferencing pointer to incomplete type
 main.c:62: error: dereferencing pointer to incomplete type
 main.c:62: error: 'TYPE_DOUBLE' undeclared (first use in
 this function)
 main.c:63: error: dereferencing pointer to incomplete type
 main.c:63: error: 'YES' undeclared (first use in this
 function)
 main.c:64: error: dereferencing pointer to incomplete type
 main.c:65: error: dereferencing pointer to incomplete type
 main.c:70: error: dereferencing pointer to incomplete type
 main.c:71: warning: assignment makes pointer from integer
 without a cast
 main.c:76: warning: assignment makes pointer from integer
 without a cast
 main.c:77: error: dereferencing pointer to incomplete type
 main.c:77: error: 'DCELL_TYPE' undeclared (first use in this
 function)
 main.c:93: error: 'DCELL' undeclared (first use in this
 function)
 main.c:93: error: expected ';' before 'd'
 main.c:96: error: 'proj_info' undeclared (first use in this
 function)
 main.c:99: error: 'unit_info' undeclared (first use in this
 function)
 main.c:102: error: 'proj' undeclared (first use in this
 function)
 main.c:111: error: 'd' undeclared (first use in this
 function)
 main.c:111: error: expected expression before ')' token
 main.c:123: error: dereferencing pointer to incomplete type
 main.c:145: warning: dereferencing 'void *' pointer
 main.c:147: error: expected expression before ')' token
 main.c:157: error: 'outName' undeclared (first use in this
 function)
 directory
 directory
 directory
 directory
 without a cast
 this function)
 only once
 without a cast
 this function)
 without a cast
 without a cast
 this function)
 function)
 without a cast
 without a cast
 function)
 function)
 function)
 function)
 function)
 function)
 function)
 lipo: can't figure out the architecture type of: /var/folder
 s/dm/x_m7msz48xj_9c0059b59rf00000gn/T//cc2vag11.out
 make: *** [OBJ.x86_64-apple-darwin12.2.0/main.o] Error 1
 ERROR: Compilation failed, sorry. Please check above error messages.
Ticket URL: <https://trac.osgeo.org/grass/ticket/854#comment:23>
