[GRASS-dev] new osgeo4w-python and winGrass643RC3-standalone: error in GUI startup
Allar Haav allar.haav at gmail.com
Sun Apr 21 03:37:34 PDT 2013
I can confirm the problem with GRASS 7, but only with osgeo4w installer.
When using standalone from http://wingrass.fsv.cvut.cz/grass70/ I have
no issues. Mind you, however, there's the osgeo4w based standalone
available too which I did not test.
Regards,
Allar
On 21/04/2013 10:16, Markus Neteler wrote:
> On Sun, Apr 21, 2013 at 11:13 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>> I have tested the winGRASS standalone installer which
>>> I got from Helmut on Windows8,
>> here Win7
>>> Should we put out this installer anyway?
>> IMHO yes, a wider test is needed to see if it's a local problem, a windows
>> version problem, a osgeo4w problem ... osgeo4w has changed the python
>> version anyway ... and the winGRASS standalone is based on it
> So let's completely release it and see... it is still RC3
> and not the final one.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
