[GRASS-dev] Grass 7: segmax and npmin confused in r.fillnulls / v.surf.rst
Helena Mitasova hmitaso at ncsu.edu
Tue Apr 23 06:19:16 PDT 2013
Stefan,
I think you should file a ticket for this,
Helena
On Apr 22, 2013, at 4:37 AM, SBL wrote:
> Hi
> I am struggeling a bit with r.filnulls on a big raster (60,000 x 50,000
> cells) with lots of "NULL" areas (ca. 52,000 holes).
> In trac I provided a patch for speeding-up r.fillnulls ( #1938
> <http://trac.osgeo.org/grass/ticket/1938>  ). But it still feels pretty slow
> on such a big raster...
> In particular, I was stumbeling upon the following waring message
> If number of points is below 600, then both segmax and npmin are set to
> "pointsnumber". So, from r.fillnulls segmax was set to 40 (and not 80, like
> the warning message indicates...). Then I tested in v.surf.rst with a hole
> with 1033 existing data points on the edge, and now I am a little confused:
> If I set
> I get the following Warning message:
> And interpolation is done within 6 seconds.
> I get the same message if I set:
> But now processing takes now 16 seconds...
> The warning message above changes to
> when I set:
> Strange that it is possible because in the GUI it says npmin has to be
> greater than segmax...
> But processing time is down on 6 secs again...
> With:
> I get the expected error message, that npmin has to greater than segmax.
> Finally, I set segmax and npmin to the "default" in r.fillnulls for holes
> with pointnumber >= 600:
> Now processing takes 55 seconds!!!
> This is especially confusing because during the tests with npmin = 1033 I
> got the following warning message in addition:
> But actually, processing was nearly 10 times faster then with npmin=300!
> Sorry for the long post!
> Summary:
> Something seems to be confused in the way v.surf.rst handles the user input
> and gives warning/error messages...
> Shall I file a ticket?
> Cheers
> Stefan
> P.S.: BTW, using the "dmin" in r.fillnulls could improve the processing
> speed for bigger holes some more. Maybe it is worth giving the user the
> option to set dmi also in r.fillnulls?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Grass-7-segmax-and-npmin-confused-in-r-fillnulls-v-surf-rst-tp5048683.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
