[GRASS-dev] [GRASS GIS] #1943: configure.in: LOC_CHECK_LIB_PATH() does nothing?
    trac at osgeo.org
    Tue Apr 23 19:36:46 PDT 2013
  Reporter:  hamish     |       Owner:  grass-dev@…
      Type:  defect     |      Status:  closed
  Priority:  normal     |   Milestone:  7.0.0
 Component:  Compiling  |     Version:  svn-trunk
Resolution:  invalid    |    Keywords:  configure.in
  Platform:  Linux      |         Cpu:  x86-64
Changes (by hamish):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [comment:1 glynn]:
 > (the first argument specifies the name of the switch,
 this was my error. the upper/lower cases was not the same as the switch's
 name, so the rest wasn't getting picked up.
 fixed in r55961, Platform.make now gets the contents of the --with-xx-libs
 line.
 I still don't understand why it doesn't pick up my libOpenCL.so in the
 ldconfig'd /opt dir, but that's another matter..
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1943#comment:3>
