[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Thu Apr 25 19:47:11 PDT 2013
  Reporter:  antonioall   |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  critical     |   Milestone:  6.4.3
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:  v.in.lines, g.tempfile
  Platform:  MSWindows 7  |         Cpu:  x86-64
Comment(by hamish):
 Glynn suggested the reason that the script-with-a-script was not working
 from the C:\> Command line version of wingrass 6.x was that the
 $GISBASE\scripts dir was missing from the %PATH% there. This is indeed the
 case, and adding it to the %PATH% allows v.in.lines (and any other script
 which calls another shell script) to run successfully.
 $GISBASE/bin is in there twice, that will need a test-before-adding too
 (maybe in env.bat?)
 tcl/tk eating the C: string remains open.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:18>
