[GRASS-dev] [GRASS GIS] #2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
GRASS GIS trac at osgeo.org
Fri Aug 2 03:10:29 PDT 2013
 Reporter:  mlennert                  |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  wxGUI                     |     Version:  svn-trunk
 Keywords:  r.in.gdal, v.in.ogr, gui  |    Platform:  Unspecified
      Cpu:  Unspecified               |
Comment(by martinl):
 Replying to [comment:3 martinl]:
 > Replying to [comment:1 annakrat]:
 > > The button was removed in r54618. I don't have any strong opinion on
 this. Perhaps the button might be confusing for users?
 > I would say that this button can be confusing to the normal user.
 Advanced users can launch r.in.gdal's autogenerated dialog from wxGUI
 command prompt by running `r.in.gdal --ui`.
 Moreover running `r.in.gdal` from wxGUI command line should also launch
 GUI front-end. The autogenerated dialog should appear only when `--ui`
 switch is used. Similarly for the other modules which have special
 frontend, e.g. `i.group`. From my personal experience, the user in the
 class were very confused when they got different GUI dialog when running
 `i.group` from the menu and command prompt.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:4>
