[GRASS-dev] [GRASS GIS] #2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
GRASS GIS trac at osgeo.org
Sun Aug 4 06:41:12 PDT 2013
 Reporter:  mlennert                  |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  wxGUI                     |     Version:  svn-trunk
 Keywords:  r.in.gdal, v.in.ogr, gui  |    Platform:  Unspecified
      Cpu:  Unspecified               |
Comment(by martinl):
 Replying to [comment:12 wenzeslaus]:
 > Replying to [comment:11 martinl]:
 > > Replying to [comment:10 hamish]:
 > > > For r.{in,out}.gdal might I suggest to revive the idea of using the
 name "r.import" and "r.export", and have those launch the GUI front-end.
 > > right, it would also fits `[r|v].external[.out]` modules. +1 for that.
 > Do you mean `[r|v].import` to be GUI-only module? If yes, note that this
 would be the first case in GRASS 7 when the module has only GUI and there
 is no non-GUI functionality. For example `i.class` was the same case in
 GRASS 6 (GUI-only module) and the new wxGUI port of `i.class` was named
 `g.gui.iclass` to explicitly say that it is GUI-only.
 no, I thought that we are speaking about renaming
  * r.in.gdal -> r.import
  * v.in.ogr -> v.import
  * r.out.gdal -> r.export
  * v.out.ogr -> v.export
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:13>
