[GRASS-dev] [GRASS GIS] #2054: d.barscale module gui doesn't start from the command line
GRASS GIS trac at osgeo.org
Sun Aug 4 13:03:31 PDT 2013
  Reporter:  hamish    |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  6.4.4
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:  fixed     |    Keywords:  d.barscale
  Platform:  Linux     |         Cpu:  x86-64
Changes (by hamish):
  * priority:  major => critical
  * status:  new => closed
  * resolution:  => fixed
Comment:
 tested in relbr64 and devbr6, all seems well now, thanks.
 d.barscale works from the wxGUI, but if you press the [Set options] button
 there to get something custom you get the breakage. I suggest packagers
 apply Anna's patch to the 6.4.3 packages as part of their build process.
 'd.erase --ui' was the only other display module I found with the trouble.
 What was the connection with the color picker? Can we expect any others?
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2054#comment:3>
