[GRASS-dev] no more GRASS 7 for Mac
Vaclav Petras wenzeslaus at gmail.com
Sat Aug 10 05:23:51 PDT 2013
Hi Michael,
On 10 August 2013 01:47, Michael Barton <Michael.Barton at asu.edu> wrote:
> In the workaround, I start GRASS 7 and let it crash back to the
> terminal. Then I cd to ../gui/wxpython and run…
>  python core/toolboxes.py > xml/menudata.xml
>  This builds a new menudata.xml file.
>  That still works.
try also
python core/toolboxes.py "module_tree" > xml/module_tree_menudata.xml
There were two changes in toolboxes/menu creation: addons are listed and
module tree in module search tab in lmgr uses different tree (file). It
seems that the workaround is needed for both files (this makes sense for me
since they are equivalent, so I hope it will work).
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130810/de926a8c/attachment.html>
