[GRASS-dev] Why the parameters of "g.region" are defined as string?
Hamish hamish_b at yahoo.com
Mon Aug 12 22:29:59 PDT 2013
Ben:
> It needs to be a string, so that you can use
> common lat/lon notations in the format "°dd'mm''ss".
technically it's like ddd:mm:ss.ssssH.
see the v.in.ascii man page. fwiw GMT mapping uses something similar.
regards,
Hamish
ps- the wxgui loc'n wizard still doesn't support that? :-(
