[GRASS-dev] v.in.ascii Column numbers must not be negative
Nikos Alexandris nik at nikosalexandris.net
Wed Aug 14 23:30:23 PDT 2013
Yann Chemin wrote:
> Hi,
Bonjour!
> (using trunk built today)
> I am trying to vector import from ascii files with 1000s of columns by
> taking x=0 y=1 and z=$col
> I must do it wrong:
> > v.in.ascii -z input=bior1.1_rcA2.csv output=bior1.1_rcA2_0000
> > separator=',' x=0  y=1 z=2 --o ERROR: Column numbers must not be negative
Yann,
maybe "x=1, y=2, z=$col" where $col should be else than 1, 2
> Data files are like this:
> (Lat, long, zval1, zval2, ...)
> 6.8000001907,55.1500015259,3.0500001907,4.3499999046,...
> 6.7000001907,55.1400015259,1.0200001907,7.3599999046,...
Can you share demo-data, a few lines?  I can also try to give it a go.
Nikos
