[GRASS-dev] GRASS 7 fails to start on OS X
Michael Barton michael.barton at asu.edu
Mon Aug 19 12:13:49 PDT 2013
A couple of questions Royce,
1. Both GRASS 6 and 7 require frameworks (dependencies). As of Friday, the dev versions (including GRASS 7) require several newer versions of the frameworks than does the stable version of GRASS (6.4.3). Did you download all required framework versions?
2. Have you installed a 3rd party python (e.g., Macpython) or a separate install of wxPython?
3. What version of the Mac OS are you running?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 19, 2013, at 12:01 PM, <grass-dev-request at lists.osgeo.org>
 wrote:
> From: "Cline, Royce L." <rcline at nd.gov>
> Subject: [GRASS-dev] GRASS 7 fails to start on OS X
> Date: August 19, 2013 9:51:02 AM MST
> To: "grass-dev at lists.osgeo.org" <grass-dev at lists.osgeo.org>
> Installed Aug. 16 GRASS 7 from Michael Barton's site. It fails to start, if I have GRASS 6.4.3 installed with the following error:
> Traceback (most recent call last):
>  File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gis_set.py", line 38, in <module>
>    from core import globalvar
>  File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/globalvar.py", line 50, in <module>
>    from grass.script.core import get_commands
> ImportError: cannot import name get_commands
> The problem appears to be occurring because
> /Applications/GRASS-6.4.app/Contents/MacOS/etc/python
> occurrs in PATH before
> /Applications/GRASS-7.0.app/Contents/MacOS/etc/python
> at the point of the error. I don't understand the start up process to determine where the GRASS-6.4 path is getting set.
> GRASS 7 starts if I remove GRASS 6.
> Royce
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130819/0976cb9e/attachment.html>
