[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
GRASS GIS trac at osgeo.org
Mon Aug 26 14:22:59 PDT 2013
 Reporter:  pvanbosgeo                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  critical                    |   Milestone:  7.0.0
Component:  Default                     |     Version:  svn-trunk
 Keywords:  g.region, r.colors, r.mask  |    Platform:  Linux
      Cpu:  x86-64                      |
Comment(by martinl):
 Replying to [comment:6 glynn]:
 > Replying to [ticket:1778 pvanbosgeo]:
 > > Normally when you type a command, e.g., g.region, without parameters,
 a new window for that command opens.
 > > This does not seem to work for a few commands at the moment. Three
 ones that seem to be affected are g.region, g.rename and g.copy.
 > This is normal. If a command doesn't have any required options,
 executing the command without parameters will not open a parameter dialog.
 You can force a parameter dialog to be displayed using the --ui switch.
 I would call it rather "current behaviour". It's probably confusing to the
 user. Is there any reason why the dialog is not open in this case?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778#comment:8>
