[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
GRASS GIS trac at osgeo.org
Tue Aug 27 14:44:52 PDT 2013
 Reporter:  pvanbosgeo                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  critical                    |   Milestone:  7.0.0
Component:  Default                     |     Version:  svn-trunk
 Keywords:  g.region, r.colors, r.mask  |    Platform:  Linux
      Cpu:  x86-64                      |
Comment(by glynn):
 Replying to [comment:8 martinl]:
 > I would call it rather "current behaviour". It's probably confusing to
 the user. Is there any reason why the dialog is not open in this case?
 If it's valid (so far as the parser can determine) to run a module without
 providing any options, then it will just get on with it, and not stop to
 ask for additional options.
 The real problem here is that there's no way to tell the parser that
 "some" options are required when no particular option is required.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778#comment:11>
