[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
GRASS GIS trac at osgeo.org
Thu Aug 29 04:47:25 PDT 2013
 Reporter:  pvanbosgeo                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  critical                    |   Milestone:  7.0.0
Component:  Default                     |     Version:  svn-trunk
 Keywords:  g.region, r.colors, r.mask  |    Platform:  Linux
      Cpu:  x86-64                      |
Comment(by glynn):
 Replying to [comment:12 cmbarton]:
 > Remind me again why the parser was changed so that a module does not
 open a GUI window when it is called from the command line and there are no
 required parameters.
 Because it's a nuisance having e.g. "d.erase" pop up a parameter dialog
 (or getting an error message about $DISPLAY not being set). It's also a
 nuisance having to type "d.erase bgcolor=none" when that's the default.
 The --ui flag exists if you specifically want a parameter dialog to be
 displayed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778#comment:13>
