[GRASS-dev] [GRASS GIS] #2066: wxGUI rendering fails with cairo driver
GRASS GIS trac at osgeo.org
Fri Aug 30 10:41:24 PDT 2013
 Reporter:  martinl      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.5.0
Component:  wxGUI        |     Version:  svn-develbranch6
 Keywords:  cairo        |    Platform:  Unspecified
      Cpu:  Unspecified  |
 When setting cairo display driver in wxGUI (GUI Settings -> Map display ->
 Display driver) then rendering process simply fails.
 GUI D1/5: gcmd.RunCommand(): d.vect --q map=archsites at PERMANENT
 GUI D2/5: gcmd.RunCommand(): command started
 GUI D3/5: gcmd.RunCommand(): decoding string
 GUI D5/5: DecodeString(): enc=UTF-8
 GUI D1/5: gcmd.RunCommand(): get return code 1
 GUI D3/5: gcmd.RunCommand(): print error
 GUI D3/5: gcmd.RunCommand(): print read error
 Command 'd.vect map=archsites at PERMANENT' failed
 Details: No graphics monitor has been selected for output.
 Note that in G64 cairo driver is not selectable in GUI Settings dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2066>
