[GRASS-dev] [GRASS GIS] #2139: g.parser does not allow newline character in option value for Python scripts
GRASS GIS trac at osgeo.org
Tue Dec 3 10:44:29 PST 2013
scripts
  Reporter:  wenzeslaus  |       Owner:  grass-dev@…
      Type:  defect      |      Status:  closed
  Priority:  normal      |   Milestone:  7.0.0
 Component:  Parser      |     Version:  svn-trunk
Resolution:  fixed       |    Keywords:  g.parser, scripts, newline, line break
  Platform:  All         |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I just tried one MS Windows computer with test command above and it worked
 (command fails in wrong way, see #2140, but the parameters are passed).
 Thanks for the fix. Closing the ticket, reopen when it will be failing on
 other MS Windows machines.
 To test this in correct way generate test file:
 echo "100 200" > test.txt
 Run test:
 m.proj input=test.txt proj_out="+proj=lcc +lat_1=36.16666666666666
 +lat_2=34.33333333333334 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0
 +no_defs +a=6378137 +rf=298.257222101 +towgs84=0.000,0.000,0.000
 +to_meter=1" proj_in="+proj=merc +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
 +k=1.0 +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000
 +to_meter=1
 Check output:
 10024493.03|-20933.49|0.00
Ticket URL: <https://trac.osgeo.org/grass/ticket/2139#comment:2>
