[GRASS-dev] i.segment: Invalid region id -1
Nikos Alexandris nik at nikosalexandris.net
Tue Dec 3 14:05:34 PST 2013
On Tuesday 03 of December 2013 21:18:36 Markus Metz wrote:
> >> > But it does not make sense to use a pan band as seeds when segmenting
> >> > the other bands. Seeds are typically the result of a previous run of
> >> > i.segment or the result of a previous classification of the same data.
> >> Then I have inserted a small mistake in my tests/workflow. Wanted to
> >> drive "finer objects" (from Pan) in bigger ones (based on MS).
> >> Will adjust.
> The seeds map does the opposite. You probably want to do pansharpening
> first.
Ha-Yey :D  I did (in some cases). Actually, it worked in this cases! And, of
course not in the ones I did not perform pan-sharpening.
Nikos =)
ps- Ah, as for the "-1", I can reproduce it with the data I am working on.
Care for more details (during the weekend)?
