[GRASS-dev] trying to compile GRASS 7 on Mavericks
Anna Petrášová kratochanna at gmail.com
Wed Dec 4 18:16:16 PST 2013
On Wed, Dec 4, 2013 at 6:39 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> Some updates.
> I changed my terminal environment and configure string for Lion (OSX 10.7)
> compatibility. This involves:
> export MACOSX_DEPLOYMENT_TARGET=10.7
> export CXX=g++
> ./configure --with-macosx-sdk=/Developer/SDKs/MacOSX10.7.sdk
> --with-freetype
> --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
> /Library/Frameworks/FreeType.framework/unix/include"
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
> --with-proj
> --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
> --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-cairo
> --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo
> /Library/Frameworks/cairo.framework/unix/include"
> --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib
> --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql
> --with-sqlite
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x
> --with-cxx --with-opengl=aqua --without-readline
> --prefix=/Applications/GRASS --enable-macosx-app --with-python
> --with-wxwidgets=/usr/local/lib/wxPython-2.9.5.0/bin/wx-config
> --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
> /Library/Frameworks/Tk.framework/Headers
> /Library/Frameworks/Tk.framework/PrivateHeaders"
> --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386
> x86_64" --with-liblas="/usr/local/bin/liblas-config" --with-opencl
> When I did this, r.terraflow and r.viewshed compiled.
> I still have the xml problem
> This message is still repeating in the terminal:
> 2013-12-04 16:25:16.568 Python[17513:d0b] CoreText performance note:
> Client called CTFontCreateWithName() using name ".Lucida Grande UI" and got
> font with PostScript name ".LucidaGrandeUI". For best performance, only use
> PostScript names when calling this API.
If this is not causing anything, I would ignore it, this is apparently
related to Maverick, maybe they will fix it later.
> A raster map displays fine
> When I first tried NVIZ, I got an error in the terminal. When I tried it
> again, it worked and the error disappeared (so I cannot copy and paste it
> here).
> I got this warning once:
> /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gui_core/goutput.py:234:
> wxPyDeprecationWarning: Call to deprecated item 'SetVirtualSizeHints’.
This is harmless, I could probably remove the  calls of
SetVirtualSizeHints, but I am not sure if it is needed in the older
wxPython versions.
> The digitizer is acting funny. When I called my new test vector “delete”,
> it crashed the GUI. When I tried it again, with “testdelete1” it is OK. But
> now it is giving me an error that the cat number is duplicated  with my
> first area. It is locked up and I can’t get out of some kind of loop with
> the dialog to create a table entry. But this may be problems with the
> digitizer in general rather than the new compilation.
> I had the GUI lock up earlier but it seems to be working OK now, if a bit
> sluggish. Tearoff menus are fine. The vector graphics look much nicer. I
> think that Cairo is displaying better with this wxPython.
Please report the issues (via trac) related to the wxPython 2.9, I already
tried to fix some of these but there will be more of them. I need the
issues to be reproducible.
Anna
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> www:    http://csdc.asu.edu, http://shesc.asu.edu
>                 http://www.public.asu.edu/~cmbarton
> On Dec 4, 2013, at 3:54 PM, Michael Barton <michael.barton at asu.edu> wrote:
> > Forgot to mention that r.terraflow and r.viewshed do not compile. I
> assume this is a C++ issue.
> > Michael
> > C. Michael Barton
> > USA
> > On Dec 4, 2013, at 3:50 PM, Michael Barton <michael.barton at asu.edu>
> wrote:
> >> I was able to compile and open GRASS 7 under Mavericks. Here is what
> I’ve done so far.
> >> 1. I had to uninstall and reinstall Xcode and the CommandLineTools. You
> may or may not have to do this. If you have not yet updated Xcode, you
> should delete your existing Xcode before doing so. There are several
> approaches to doing this depending on how you installed it. There are
> references to using an Uninstall_Devtools utility that supposedly lives in
> /Library/Developer. I’ve never had this. If you installed from the app
> store, you need to open the launch pad and delete Xcode from there. AFAIK,
> there is no way to delete the CommandLineTools (unless you want to do it
> one by one). I also installed the AuxTools because I had these before. I
> don’t know that I need them though.
> >> 2. I also installed wxPython 2.9.5 so I can compile in 64bit Python
> 2.7. I also installed all the current frameworks from William’s site (I
> only had to update to GDAL 1.10)
> >> 3. I had to drop out of my configuration script reference to gettext
> and odbc. I supposed I need to recompile gettext under Mavericks (and maybe
> LAS but I don’t yet know). But I don’t know where the ODBC issue is coming
> from. I didn’t explicitly install that previously.
> >> 4. I opened a terminal window, cd to the proper source directory and
> then typed…
> >> export CXX=g++
> >> 5. I configured with…
> >> ./configure --with-freetype
> --with-proj
> --with-cairo
> --with-sqlite
> >> 6. I ran…
> >> make GDAL_DYNAMIC=
> >> 7. I ran…
> >> make bindist
> >> Making a binary distribution package partly failed. I got a GRASS app
> but not a package, because the packagemaker is no longer with the AuxTools.
> I’ll need guidance from William as to how to use whatever new package
> making tools are in the Dev Tools.
> >> So far, I have not compiled for 10.7 compatibility or bundled wxPython
> (I’m doing that now)
> >> wxPython still crashes on startup due to its inability to create
> menutree.xml and module_tree_menudata.xml. I have to do a work around. I
> was hoping that this might clear up with Python 2.7 and wxPython 2.9. But
> it has not. So this is a problem in the code and not in trying to maintain
> backward compatibility.
> >> Once I did all this, GRASS 7 launches. It looks different with wxPython
> 2.9—more Linux like and less Maclike to my eyes.
> >> Also, the terminal begins kicking out the following message every
> second or so:
> >> 2013-12-04 15:31:50.761 Python[78631:d0b] CoreText performance note:
> >> This needs to be fixed.
> >> I’ll keep you all informed about compiling for Lion and packaging
> wxPython.
> >> Michael
> >> C. Michael Barton
> >> USA
> >> On Dec 3, 2013, at 5:53 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> >>> Michael,
> >>> can you please share your configure file that you are using?
> >>> thanks, Helena
> >>> Helena Mitasova
> >>> Associate Professor
> >>> Department of Marine, Earth, and Atmospheric Sciences
> >>> 2800 Faucette Drive, Rm. 1125 Jordan Hall
> >>> North Carolina State University
> >>> Raleigh, NC 27695-8208
> >>> hmitaso at ncsu.edu
> >>> "All electronic mail messages in connection with State business which
> are sent to or received by this account are subject to the NC Public
> Records Law and may be disclosed to third parties.”
> >>> On Dec 3, 2013, at 7:12 PM, Michael Barton wrote:
> >>>> I got it to compile fine using GDAL 1.10. But the GUI still crashes
> on startup due to problems in the xml toolbox.
> >>>> Michael
> >>>> C. Michael Barton
> >>>> USA
> >>>> voice:
> >>>> www:
> >>>> On Dec 3, 2013, at 12:43 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> >>>>> Hi all,
> >>>>> I am still having problems to compile GRASS on Maverick, it cannot
> find GDAL, I already reinstalled the frameworks and Xcode, too. I tried to
> compile the simple code which seems to be compiled during configure:
> >>>>> #include <gdal.h>
> >>>>> int main(int argc, const char* argv[])
> >>>>>  GDALOpen("foo", GA_ReadOnly);
> >>>>> which gives me:
> >>>>> gis-imac:Desktop akratoc$ gcc test.c
> >>>>> test.c:14:5: warning: ignoring return value of function declared
> with warn_unused_result attribute [-Wunused-result]
> >>>>> 1 warning generated.
> >>>>> Undefined symbols for architecture x86_64:
> >>>>> "_GDALOpen", referenced from:
> >>>>>    _main in test-sew0gz.o
> >>>>> ld: symbol(s) not found for architecture x86_64
> >>>>> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> >>>>> I am having the same problem also on another computer. Any help
> appreciated.
> >>>>> Thanks,
> >>>>> Anna
> >>>>> On Fri, Nov 29, 2013 at 3:27 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >>>>> On Fri, Nov 29, 2013 at 9:02 PM, Michael Barton <
> Michael.Barton at asu.edu> wrote:
> >>>>>> I've been chilling out after Thanksgiving and thought I'd try
> compiling
> >>>>>> GRASS on Mavericks.
> >>>>>> I had a couple of configure issues.
> >>>>>> --with-odbc failed. Is this not included with Mavericks or do I
> need to
> >>>>>> reference it in some other way?
> >>>>>> --with nls also failed. I wonder if I have to update the version of
> gettext
> >>>>>> that I compiled on Lion?
> >>>>>> When I dropped these out, I got it to compile. But it errors out
> with the
> >>>>>> following:
> >>>>>> "___sincos_stret", referenced from:
> >>>>> I found these "random" links:
> >>>>> http://trac.macports.org/ticket/40961
> http://stackoverflow.com/questions/19015780/sincos-stret-undefined-symbol-when-linking
> >>>>> Perhaps giving the right idea..
> >>>>> Markus
> >>>>> _______________________________________________
> >>>>> grass-dev mailing list
> >>>>> grass-dev at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131204/714119fa/attachment-0001.html>
