[GRASS-dev] segfault on 'r.stream.extract' - debian armh
epi massimodisasha at gmail.com
Sat Dec 7 09:59:35 PST 2013
Hi Maris,
this is the bt :
(gdb) exec-file r.stream.extract elevation=elevation50m at PERMANENT accumulation=accum threshold=40 stream_rast=stream_network stream_vect=streams --o
(gdb) r
Starting program: /home/epi/Envs/env1/grass-7.0.svn/bin/r.stream.extract
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Program received signal SIGILL, Illegal instruction.
0x2c99fe68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
(gdb) bt
#0  0x2c99fe68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
Cannot access memory at address 0x0
#1  0x2c99db2c in OPENSSL_cpuid_setup ()
#2  0x2aab60d6 in call_init (env=0x7efff35c, argv=0x7efff354, argc=1,
    l=<optimized out>) at dl-init.c:84
#3  call_init (l=<optimized out>, argc=1, argv=0x7efff354, env=0x7efff35c)
    at dl-init.c:34
#4  0x2aab6158 in _dl_init (main_map=0x2aaca958, argc=1, argv=0x7efff354,
    env=0x7efff35c) at dl-init.c:133
#5  0x2aaabc62 in _dl_start_user () from /lib/ld-linux-armhf.so.3
#6  0x2aaabc62 in _dl_start_user () from /lib/ld-linux-armhf.so.3
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb)
rebuilding with :
gcc  -g -Wall -O0
gave me no worning  in r.stream.extract
On Dec 6, 2013, at 6:36 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Any warnings during compilation?
> Try to compile with -g and -O0 to get slow but debugging-friendly version.
> When program gets stopped by SIGILL in gdb, issue "bt" command to get backtrace.
> No help form me, but more info never hurts ;)
> Maris.
> 2013/12/6 epi <massimodisasha at gmail.com>:
>> Hi !
>> this the output of gdb :
>> 0x2c966e68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
>> (gdb)
>> Thanks for your help!
>> Massimo.
>> On Dec 6, 2013, at 4:16 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
>> Hello Massimo,
>> A gdb output could be more helpful for a segfault
>> On Fri, Dec 6, 2013 at 7:06 PM, epi <massimodisasha at gmail.com> wrote:
>>> Hi,
>>> i’m trying to run  “r.stream.extract” on a little linux machine, i got got
>>> grass up and running on a small quad-core Arm 1gb ram
>>> OS :  Debian SID ArmHF.
>>> the command i’m using is :
>>> r.stream.extract elevation=elevation at PERMANENT accumulation=accum
>>> threshold=40 stream_rast=stream_network stream_vect=streams --o --q
>>> location :  nc_spm_08_grass7/PERMANENT/
>>> i set the debug level to 5, this the segfault log :
>>> https://gist.github.com/epifanio/7829206
>>> if helpful, this is the log of make clean and make :
>>> https://gist.github.com/epifanio/7829256
>>> On other platform (same grass and r.stream.extract version it wks just
>>> fine)
>>> Have you any idea on what’s wrong ?
>>> Thanks,
>>> Massimo.
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Regards,
>>   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131207/cfe9120c/attachment.html>
