[GRASS-dev] trying to compile GRASS 7 on Mavericks
Michael Barton Michael.Barton at asu.edu
Sat Dec 7 13:35:44 PST 2013
On Dec 7, 2013, at 11:27 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> On Dec 7, 2013, at 12:04 PM, Michael Barton wrote:
>> Additional good news. I grabbed a copy of the old packagemaker.app from the XCode 4 auxtools, dropped it into /Developer/Aux_tools/ (where I had it before), and it seems to work find for making a GRASS 7 package.
> Another casualty in Xcode.  We need to figure out how to use the new packaging tools.  Packagemaker was deprecated in Xcode 4 in favor of more raw tools (which are also necessary for signing): pkgbuild, productbuild and pkgutil.  I found a stackoverflow question with some good info to start with, I just haven't sat down and tried anything yet.
At least the old packagemaker.app still seems to work in the meantime
> http://stackoverflow.com/questions/11487596/making-os-x-installer-packages-like-a-pro-xcode4-developer-id-mountain-lion-re
>> Now I just need to get odbc and gettext to configure again and I'm back in business.
>> odbc seems to be in /Library/ODBC
>> Can I just add --with-odbc="/Library/ODBC" in the configure string?
> /Library/ODBC is just for ODBC drivers.
> ODBC should still be iODBC, and --with-odbc should be enough.  Unless Apple completely reorganized iODBC.  Is libiodbc.dylib in /Library/ODBC?  Are headers in there?
Nothing is in my /Library/ODBC except a couple of very old (2003) files: odbc.ini and odbcinst.ini.
Could it be someplace else? I could find nothing named ODBC in the other Library folders.
Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
